1999 Toyota Camry Engine makes a humming sound when driving
116,200 MILES • 4 CYL • 2WD • AUTOMATIC
FREDERICKG
My engine makes a loud humming sound that gets loudest between 30 and 40 mph. Above 40 mph the hum quiets down a bit. The engine does not make the sound while idle. The sound appears to be coming from the left side of the engine. This issue started a few weeks after I had my water pump and timing belt replaced. I'm not sure if the issue is related to this repair but I wanted to include it just in case. I have heard that humming can be caused by a faulty PCV valve. My PCV valve was replaced about 20K miles ago. Would it be worth replacing this?
Sep 17, 2009 at 7:02 AM
BMRFIXIT
  • 19,053 POSTS
Its in the engine and not the wheels !!
try to put a pressure on the steering wheel little to the left and then to the right if sound change
suspect wheel bearing
also another possible the idler tensioner for the T belt may be defective
but most the time you can hear it when reving up engine in neutral /park
Sep 18, 2009 at 1:19 PM
