1999 Toyota Camry Alignment & Shocks
110,000 MILES • 6 CYL • FWD • AUTOMATIC
SUNFLOWER73
I have recently had an alignment done on my car because it was pulling to the left. I got it back and it is still pulling to the left enough that when other people drive my car they comment on it.
I'm tired of getting the run around by my mechanic and want to know if it has anything to do with the shocks/brakes, etc???? I just want to know what i need to get looked at and estimated before i put a lot of money into my car. Could someone give me some answers????
Mar 15, 2008 at 8:34 AM
MASTERTECHTIM
  • 4,750 POSTS
if the alignment is in specs then your problem is a tire pull. cross rotate your tires and if the pull goes to the other side then replace tires. hope this helps
Mar 15, 2008 at 8:45 AM
MASTERTECHTIM
  • 4,750 POSTS
you probably have 2 different problems. the banging noise is usually related to the front end sway bar end links. the pulling is alignment or tires. if you have not installed new front end sway bar end links yet, then that is what i would have done first, they are the first component to fail. **always reply to the post you start, to help other people that may be experiencing the same problem
Mar 15, 2008 at 8:57 AM
