HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
General
Noises
Click
1998 Toyota Camry Clickes when turning.
RECRULIONIX
MEMBER
1998 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
96,000 MILES
Every turn I make, it'll grind. I believe its the CV joints. What do I replace, the joint or boots?
Saturday, February 20th, 2010 AT 7:15 PM
MECHANIC
Most likely its gonna end up with the CV Joints if the boots are in good shape
Saturday, February 20th, 2010 AT 7:44 PM
HOMER1967
MECHANIC
You should replace as a unit so ask for a cv shaft or half shaft they will know what you mean. Hope this helps
Saturday, February 20th, 2010 AT 7:56 PM
Please
login
or
register
to post a reply.
Related Noise Click Content
When Trying To Crank Engine It Just Clicks
So I Was Trying To Start 98 Toyota Camry Le And It Wouldn't Start It Would Just Click Repeatedly. I Was Thinking It Was My Starter. But Is...
Asked by
hannahharris87
1 IMAGE
1998
TOYOTA CAMRY
1998 Toyota Camry Help! Can't Fill Car With Gas
Every Time We Go To Fill Up I Can Only Put.50 Cents In Before The Pump Handle Clicks Off Acting Like It's Full. It Takes About 10 To 15...
Asked by
cmcanoe
1 ANSWER
1998
TOYOTA CAMRY
2000 Toyota Camry Starter Clicks
Sometimes When Attempting To Start, The Starter Will Click As If The Solenoid Is Energizing. The Starter Does Not Engage. Then I Can Put It...
Asked by
southernbynature
1 IMAGE
2000
TOYOTA CAMRY
1994 Toyota Camry 94 Camry Front Driver Clicking...
I Hear A Clicking Noise Coming From The Front Driver Side Of The Car. It Only Happens When The Car Is Moving At 10mph Or More. It Occurs...
Asked by
Jaxcar
1994
TOYOTA CAMRY
My Undercarriage Plastic Is Loose And I Hear Noise...
My Car Was Making This Clicking Sound Every Time I Make A Turn And The Undercarriage Plastic Cover Is Loose And Dragging The Ground. I Do...
Asked by
Lmg
1 ANSWER
2004
TOYOTA CAMRY
VIEW MORE
Grinding Noises
Howling
Radiator Hoses and Thermostat Replacement
