1998 Toyota Camry Car will not crank some times only.
ATUL123456
  • 1998 TOYOTA CAMRY
  • 4 CYL
  • 137,000 MILES
My camry will not start some times. It will not even crank while other times it will start fine. I changed battery at sears and still same thing.
Thursday, January 22nd, 2009 AT 4:35 PM
Could be the ignition switch, park and neutral switch, starter relay and the starter itself
Thursday, January 22nd, 2009 AT 5:08 PM
KEVIN12881
  • 336 POSTS
Are there any patterns? Does it start easier when cold? Staring easier when cold- it may be starter. Cars are harder to start (at least for the starter) when hot because there is still pressure in the cylinders. If this is not the case, and even if it is, look into what rasmataz has said
Thursday, January 22nd, 2009 AT 5:25 PM
