1998 Toyota Camry AC comes on and off
1998 TOYOTA CAMRY
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
FIREFOX60
My A/C used to work great. Then it quit and the way I found to get it turned back on was to flip the inside/outside air vent lever back and forth and then it would pop on again.
Then the fan started to get slower and slower and would suddenly get fast air coming out.
I did notice that when I went over a speed bump the air would increase for about a second and then go back down
Now it comes back on when it wants to but the fan is very slow. Still has very very cold air though.
Just went out and drove and the AC came back on. More like a medium high air flow. It's almost as if something is clogging it all up like a vacuum hose?
Jun 11, 2010 at 1:21 AM
KHLOW2008
  • 41,814 POSTS
Hi firefox60,
Thank you for the donation.
Symptoms indicates the fan motor is fasiling. The carbon brushes are running out and it is intermittently not working correctly.
Give the blower housing some banging with your hands to see if the motor works better. If yes, it is time to get the motor replaced.
Jun 11, 2010 at 5:57 AM
FIREFOX60
Thank you, I will pass that on to whoever works on it.
Jun 11, 2010 at 10:45 AM
KHLOW2008
  • 41,814 POSTS
You're welcome and hope the problem is resolved soon.
Have a nice day.
Jun 18, 2010 at 12:52 AM
