1997 Toyota Camry Toyota camy wont come out of park
DCARNEY
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 112,000 MILES
1997 Camry with an automatic transmission will not come out of park. Also, the electric windows, heater, radio, blinkers do not work. Is the transmission issue somehow tied into a blown fuse or open electrical circuit somewhere?
Tuesday, December 18th, 2007 AT 6:06 PM
BLACKOP555
  • 10,371 POSTS
Sounds like a fuse/relay problem to me.
Does the brake lights turn on?
Check all fuses.
Turn the key right before the on position and right before the lights come on, it should bypass the mechanism and the car should be able to shift to neutral.
Tuesday, December 18th, 2007 AT 7:29 PM
