1997 Toyota Camry Noise when braking
1997 TOYOTA CAMRY
206,000 MILES • 4 CYL • FWD • AUTOMATIC
PGRIGNON02
I recently had the front pads replaced and brake fluid changed on my Camry. Since that work, I hear a pulsing/rubbing sound from the front right side of the car when braking. It sounds a little like the sound make my a steam train. This is most noticable after driving a little while and braking at low speeds. I have had car back to shop a couple times and each time they inspect and say brakes are in good shape. They also have re-lubricated the pistons during one of these checks. To rule out suspension noise (and since it had not had attention for 100K miles), I went ahead and had 4 quick struts installed. However, I still get the low speed brake noise. What can be done to fix this noise?
Aug 11, 2010 at 8:30 AM
