Tuesday, October 7th, 2008 AT 5:33 PM
My camry has a strange problem. It idles fine but when Igive it gas sometimes is feels like it is running on 3 cyl. Then it straightens out and runs fine. It does not do this all the time. I tested the spark and compression and all is good. The fuel filter is new but I dont have a fuel pressure tester to verify the fuel is at the right pressure. There is a egr valve code but the misfire has happened a while after the light came on. Where should I look next?
