HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Drivetrain
Transmission
Fluid
1997 Toyota Camry dts codes
BONIFACIO2
MEMBER
1997 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
22,000 MILES
I came with a code of p0770 that the shoft selenoid is malfunction do I need to change the transmission oil?
Sunday, January 24th, 2010 AT 10:27 PM
BLUELIGHTNIN6
MECHANIC
DTC p0770 : Lock-up Solenoid (also called SL solenoid)
Possible causes are:
Lock-up solenoid is stuck open or closed
Valve body clogged or valve stuck
TCC (torque converter clutch) malfunction
Sunday, January 24th, 2010 AT 10:41 PM
Please
login
or
register
to post a reply.
Related Transmission Fluid Content
1993 Toyota Camry Transmission Fluid Came Out Of...
Hello, I Have Just Put A Used Transmission In My Toyota Camry And About 2 Weeks After I Installed It I Was Driving It And The Car Stopped...
Asked by
daviddlw
1993
TOYOTA CAMRY
1995 Toyota Camry Vibrating Wheel And Transmission...
1995 Toyota Camry 4 Cyl Front Wheel Drive 99,432 Miles My Toyota Camry's Steering Wheel Vibrates When I Accelerate To And Above 35 Mph...
Asked by
Mellow249
1995
TOYOTA CAMRY
Transmission Fluid
If The Tranny Fluid Is Almost Clear (slightly Pink On A Napkin), Is This A Sign That Something Has Been Added To Hide A Weak Transmission?
Asked by
D. McCormick
1998
TOYOTA CAMRY
Too Much Transmission Fluid
My '98 Camry With Automatic Transmission Has Taken An Extra Second To Get In Gear The Past 2 Days, So I Checked The Fluid Level. It...
Asked by
daveyahoo
1998
TOYOTA CAMRY
Transmission Fluid Dark Also No Reverse
I Have A 1993 Camry 6 Cyl 3 Litre I Changed Trany Fluid And Filter Last November At 30k Miles The Car Would Not Go In Reverse Yesterday I...
Asked by
muldoon
1993
TOYOTA CAMRY
VIEW MORE
Transmission Fluid and Filter Ford F-150
Transmission Drain and Refill
Automatic Transmission Service
