1996 Toyota Camry I dont no if its the battery or alternato
BSCLINTON19
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • 170,000 MILES
Sounds like a dead battery cause it jus clicks really fast when you turn the key in the ignition, we tried jumping the car bt nuthing. Clean terminals and battery and still nuthing, also got battery tested they said it was fully charged so I dont know what the problems is?
Wednesday, July 28th, 2010 AT 5:24 PM
No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Wednesday, July 28th, 2010 AT 8:06 PM
