1996 Toyota Camry Gasoline additive
1996 TOYOTA CAMRY
160,000 MILES • 4 CYL • 4WD • AUTOMATIC
MICHAELE99
  • 8 POSTS
Hi there! I bought a concentrated fuel injector cleaner that says I should add entire bottle to nearly empty gasoline tank, then fill tank with up to 21 gallons of gas (my tank is around 16 gallons). For best results, it says, do not refill tank until near empty. Then it says to do this every 3000 miles. It is called Gumout and it is suppose to clean fuel injectors, prevent future deposit build up and restore lost horsepower. Is this a good idea to do? Is this a waste of money? Will this hurt the engine? Should I do it every 3000 miles? Thanks. Michaele
Aug 22, 2008 at 7:14 AM
Its a good preventive maintenance for the fuel system-I don't see no problem at 3K miles or every 1/4 tank when refilled
Note: Make it a practice to refilled when your fuel level is at 1/4 tank.
Aug 22, 2008 at 8:09 AM
