1996 Toyota Camry Engine wont turn over
CHURCHILL1
  • 1996 TOYOTA CAMRY
1996 Toyota Camry 4 cyl Automatic 108000 miles
When you start my camry, the car will be turn on fine as long as you are reving the gas pedal, but as soon as you take your foot off the gas the car dies/stalls out. Any suggestions?
Thank you
Friday, December 4th, 2009 AT 3:50 PM
CHURCHILL1
  • 8 POSTS
I finally get the car to start by giving it gas for about a minute, then after that the car is fine. Does anyone have a suggestion on why this is happening?
Thanks
Wednesday, December 9th, 2009 AT 2:31 AM
KHLOW2008
  • 41,814 POSTS
Hi churchill1,
The idling system is not functioning correctly and quite often it is due to a dirty throttle body and Idle Air Control valve.
Get them cleaned and it should solve the problem.
Thursday, December 10th, 2009 AT 1:18 AM
CHURCHILL1
  • 8 POSTS
Thank you KH, I will try that and keep you updated
Friday, December 11th, 2009 AT 1:58 AM
