HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Exhaust
Catalytic Converter
1996 Toyota Camry Catalytic Converter
RONCALI
MEMBER
1996 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
179,000 MILES
Which converter is bank 1, the front one or the rear one?
Thursday, May 15th, 2008 AT 8:41 PM
BLACKOP555
MECHANIC
Convertor bank 1? You mean o2 sensor bank 1? If so its the one on the side of the engine with the #1 cylinder
which in your case is the only side of the engine you have, it will be located on the exhaust manifold BEFORE the catalytic convertor.
Friday, May 16th, 2008 AT 7:48 PM
Please
login
or
register
to post a reply.
Related Catalytic Converter Content
1996 Toyota Camry Well It's Actually A Question About...
Engine Performance Problem 1996 Toyota Camry Front Wheel Drive Automatic 239800 Miles Hi My Name Is Kristin And I Did Take My Car Into...
Asked by
KristinNaomi
1 ANSWER
1996
TOYOTA CAMRY
VIDEO
How to Test a Catalytic Converter?
Instructional repair video
GUIDE
Catalytic Converter
The engine exhaust system catalytic converter was developed in the early 1970's when severe air pollution was prevalent, and was made mandatory in automobile manufacturing...
1997 Toyota Camry Catalytic Convertor
Recently, I Began Smelling Gas Inside My Car When Idling And Asked A Friend What It Could Be. He Is Convinced It Is The Catalytic...
Asked by
seacoastbrass5
1 ANSWER
1997
TOYOTA CAMRY
Will An O2 Sensor Give The Same Code As The Front...
Recently My Car Failed Inspection Because The Check Engine Light Came On (the Day Before It Was To Go In!). The Garage Mechanic Did A Quick...
Asked by
StarB
1 ANSWER
2000
TOYOTA CAMRY
My 2005 Toyota Camry Is Making A Gurgling Or Rattling Sound And Now It Is Also Making A Clicking Sound. It All Sounds Like It Is Coming...
Asked by
jefletchr
2005
TOYOTA CAMRY
2002 Toyota Camry Catalytic Converter
I Thought This Camry Had Only One Cat Converter - I Went To A Shop And They Told Me That It Has Two-one From The Manifold In The Front And...
Asked by
usmc3521
2002
TOYOTA CAMRY
VIEW MORE
Catalytic Converter
Catalytic Converter Replacement
