1996 Toyota Camry 96 Toyota Camry hard start problem rasmat
96REALWE
  • 1996 TOYOTA CAMRY
  • 6 CYL
  • 140,000 MILES
I bought a 96 Camry V6 it was slow to start when cold but does start after you turn it over awhile. So I spray cleaned the throttle body and the IAC valve opening in the throttle body, now the car starts fine when cold but when it warms up it does the hard start thing again every third start or so, what's next?
Thanks In Advance
Bill
Monday, February 18th, 2008 AT 10:41 PM
Investigate what's happening with the fuel pressure-to rule out the fuel pressure regulator/fuel pump. Also check the throttle position/coolant temperature sensors.
Monday, February 18th, 2008 AT 11:15 PM
96REALWE
  • 39 POSTS
What should the fuel pump pressure be and where is the easiest place to hook up the guage
Thanks Bill
Friday, February 29th, 2008 AT 9:04 PM
