1995 Toyota Camry willn't start
DINGAB1
  • 1995 TOYOTA CAMRY
Engine problem
1995 Toyota Camry Front Wheel Drive 118000 miles
I turn the key on nothing happen, not even a click, I see the engine light on. I check the battery is good still new.
Sunday, December 16th, 2007 AT 8:43 PM
  • 31,937 POSTS
Check for 12V at solenoid wire at starter motor when key turned to start, check battery terminals clean and tight, check main starter cable tight and 12 volts constant. If these are ok starter is faulty.
Mark (mhpautos)
Monday, December 17th, 2007 AT 10:27 PM
