1995 Camry V6 XLE 60000 miles
1995 TOYOTA CAMRY
ESPEQUE
I does not want to shift in to high gear or 4th. It goes back and forth. I have to drive it with the O/D swicht off all the time. The "pwr" lite comes on and off all the time without activating the swicht. When I put in reverse, it also says is in "drive" in the indicator.
I have owned this car since new and have not had any problems until now, except for the brake master cylinder. It is also leaking oil thru the valve seals, but I have not paid much attention to that, they are not easy to change. Thanks for any help you can give me, and pardon my english, FNieves,PuertoRico(Espeque)
Sep 7, 2006 at 12:03 PM
  • CERTIFIED EXPERT
Have these sensors check: CTS, TPS, and VSS before you get to the solenoids 1/2/3 in the tranny.
So much of electronic controlled transmission Huh!
Sep 13, 2006 at 4:42 AM
