Hi there,
Make speedo cable is secured onto the drive at the rear of the transmission, the outer knurled nut screws onto the drive the inner cable it located into a slot, if this is loose the speedo can malfunction, if that is ok the speedo head in the dash will more than likely be faulty.
Mark (mhpautos)
Tuesday, December 30th, 2008 AT 5:35 AM
