1994 Toyota Camry Occasional engine will not turn over whe
JHOELSCH
  • 1994 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 165,000 MILES
I have had this Camry for about 4 years now. Occassionally when I try to start the car the engine turns and turns fo about a minute before it starts. The rest of the time it starts fine and there is a slight hesitation when you press the gas pedal to go. Help
Thanks
Tuesday, July 15th, 2008 AT 8:30 AM
BOBBYTECH1
  • 49 POSTS
Sounds like fuel pressure problem either caused by clogged fuel filter or weak pump so check pressure first and replace filter first if no done
Tuesday, July 15th, 2008 AT 8:50 AM
SECTORJEFF
Try changing the distributor rotor it I had the same problem and it worked like a charm
Tuesday, July 29th, 2008 AT 2:30 PM
