1994 Toyota Camry fan
JOHNHER
  • 1994 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 25,000 MILES
Heat up in about 15 min fan runs fast and the tempeture rises and lowers
Tuesday, August 3rd, 2010 AT 5:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Overheating issues can be caused by many different things. The first to check is always the coolant level. If it is at the appropriate level then the thermostat will need to be removed and tested. If the thermostat is sticking then it will not allow coolant to flow properly when it is needed.
Tuesday, August 3rd, 2010 AT 10:04 PM
Related General Content
