1994 Toyota Camry Engine idiling
JONESPTT3
  • 1994 TOYOTA CAMRY
Engine problem
1994 Toyota Camry 4 cyl Wheel Drive Type unknown Automatic 150000 miles
I believe someone put weedeater gas in my car it blows out black smoke and the engine misses now the smoke smells like weedeater gas also when I rev the engine it dies it dies sometimes when i'm in a turn too.
Saturday, December 8th, 2007 AT 2:50 PM
Welcome to 2carpros
Get the coolant temperature and oxygen sensors check-might be stuck in the open loop mode meaning its demanding more fuel than needed due to incorrect input signals or a wiring problem to the ECM. Also for a leaking fuel pressure regulator or an excessive fuel pressure.
I don't think a 2cycle oil will cause all that mess.
Saturday, December 8th, 2007 AT 3:38 PM
