1993 Toyota Camry Intermitently will run rough
LUIS DELGADO
  • 1993 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 238,000 MILES
Car has new low mileage engine. All injectors have been replace as well as catylic convertor. The car runs perfectly, but every now and then it runs rough, like if it were running on 5 cylinders.
Thanks
Monday, August 3rd, 2009 AT 4:53 PM
  • 31,937 POSTS
HI there,
This can be a high tension lead breaking down, start with the simple things first have a full tune up done and get a scan done to see if there are any set fault codes that need attention.
Mark (mhpautos)
Monday, August 3rd, 2009 AT 6:11 PM
LUIS DELGADO
The low mileage engine that I put in has less than 5,000 on it since installed. I had full tune up done on it with new wire, plugs, cap and rotor, fuel filter, air cleaner. Is there anything else you might suggest.
Thanks,
Luis
Monday, August 3rd, 2009 AT 6:32 PM
  • 31,937 POSTS
HI there, run a scan and see if there are any set fault codes, but don't presume that the other items are ok either as you may be chasing a simple faulty lead or plug.
Mark (mhpautos)
Monday, August 3rd, 2009 AT 6:39 PM
