1993 Toyota Camry I Reek Like Gas
205,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANDYCAREE
Hello all. Whenever I am done driving my car, I reek like gas. While driving, there is no noticeable smell really at all. I have taken it to 3 different shops. I have had the muffler replaced, an o-ring on the distributor replaced, and the engine and under-carriage steam washed. The going theory was that oil was leaking onto the exhaust. One of the mechanics even specialized in fuel tanks. No body can find any leaks. I still smell. I don't want to sell it, but I don't want to smell either.
Aug 6, 2008 at 12:51 PM
MASTERTECHTIM
  • 4,750 POSTS
look closely at the fuel injectors to see if they are damp, if they are you will need to replace the injector o rings or replace the injectors themselves, this is common on this car
Aug 6, 2008 at 12:53 PM
ANDYCAREE
Thanks. How do I locate the fuel injectors?
Aug 7, 2008 at 4:31 AM
MASTERTECHTIM
  • 4,750 POSTS
look at engine on the top rear side. there will be 4 of them, one at each cylinder on the opposite side of where the spark plug is
Aug 7, 2008 at 8:46 AM
