Hi stevengurrola,
There is a drain plug under the trans oil pan. Filling is via the dipstick tube.
The differential gearbox has a drain plug at the lowest portion and filling is via a filler plug located between the trans and crossmember. Not easy to fill up.
SPONSORED LINKS
Friday, June 27th, 2008 AT 9:26 AM
