1993 Camry driev shaft issue
1993 TOYOTA CAMRY
BENNY84
Hi ,
I have a 1993 Camry, 140K miles, 4 cylinder, 2200cc,
Recently I had problems when i accelerated like when getting from the ramp to the freeway, and the car started shaking until reaching a steady speed. So a mechanic changed the drive shafts of both sides and the problem is fixed now. but i have encountered that since then the car feels as if it is heavy so it doesnt accelerate as fast as before. Any reasons why this is??
I appreciate your help.
Thanks
Nov 27, 2007 at 3:12 PM
FISHERMAN
  • 937 POSTS
[quote:1db30bdd70="Benny84"]Hi ,
Thanks[/quote:1db30bdd70]
hello !!
Did you installed brand new shafts or remanufactured?
sometimes the ball joints are too tight that the "balls" on the racers get "stuck" and its really hard to transfer the power to the wheels (once on angle)..
looks hard to believe but that happens to me one time i bought a pair of "brand new" made in China drive shafts, I installed them and I can`t even turn the wheel to tight the allen screws!! I took them out and found that the steel balls wont "fit" on the racers! I had to use a moto-tool to "grind" the racers and make it fit.. after that problem fix!
after that I don`t trust those "China" replacement parts!!
find that and let us know!!
Nov 27, 2007 at 3:59 PM
BENNY84
Hi and thanks for your reply.
Yes I think they are made in China ( which is for sure) or they are remanufactured. So i think i have to take it back and get them to change them.
I also have started having 2 other problems with it.
1) is that recently when i leave the car in the cold,, like in an open parking lot for a long time like for an 8 hours work, when i start the car and try to drive away right away, the steering wheel gets tight,, or it doesn't turn to one side,, so when you try to trun the wheel,, it doesnt turn the wheel,, as if it is stuck,, but after a while,(like when the car is warm and ready to go) the problem is resolved and there is no problem driving.
2) the gas/milage ratio has increased dramatically, so it actually takes 18 litres/ 100 Km. (I do metric since i am canadian) :) i think it is 4.5 gal/60 miles.
What could that be? I have new wires and sparks plugs that i changed myself recently.
Thanks a lot for your reply.
Ben
[quote:eefe9a9f16="fisherman"][quote:eefe9a9f16="Benny84"]Hi ,
Thanks[/quote:eefe9a9f16]
hello !!
find that and let us know!![/quote:eefe9a9f16]
Nov 29, 2007 at 12:22 AM
FISHERMAN
  • 937 POSTS
Hello Ben !!
Well it looks like the power steering pump its not working right..
check all the hoses for "bending" (restricted flow) make sure that the level its right and check if in the reservoir the fluid has "Bubbles" on it that indicates air in the system also check for leaks on the system.
about the poor gas mileage...
Make check the cat. converter, correct tire pressure, clean injectors, distributor cap and rotor, could be a lot of things...
start checking those..
Good Luck and best regards!
Nov 29, 2007 at 1:12 AM
