1992 Toyota Camry hesitates & studders
RICKYGITTINS
  • 1992 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 188,000 MILES
92 camry 2.2 automatic, when stopped and you nail the gas it studders then picks up, acts like it has a rev limiter on it at about 4000 rpms, will get up to 70 mph in about a mile, new spark plugs and wires & TPS, What can it be?
.81 idle, 3.72 WOT that's connecting the black to the brown, it still spits and sputters at take off and 4200 RPM, noticed shifting is holding untill I let up on accelerator
when you are going down the road it will act up and if you turn the key off and then turn it back on before the engine stops it will reset something and run good for 1/2 mile then start all over again
suckin gas, 3 gal 40 miles
Tuesday, June 22nd, 2010 AT 9:07 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Tuesday, June 22nd, 2010 AT 3:23 PM
RICKYGITTINS
WOW, I don't think I have that kind of time or money, Someone with experiance would be nice,
I can guess
Tuesday, June 22nd, 2010 AT 3:31 PM
Try the airflow meter and EGR valve for a starter-its long but its worth checking-its not a simple problem can cause a nightmare to remember
Tuesday, June 22nd, 2010 AT 3:36 PM
