Later in the day, the jerks would occur more often once again at stop lights and then sometimes when I start the car and the car is idling.
I've had a tuneup, transmission fluid changed, clean intake induction system, clean throttle body, and fuel injection system done.
What do you think is the cause?
Thanks,
Susan
PS: Will be driving this car across country had dist cap, rotor & set timing, checked hoses, belts, fluids, battery, tires, & brakes checked. Anything else should be done?
SPONSORED LINKS
Thursday, March 27th, 2008 AT 4:18 PM
