1991 Toyota Camry Hard steering
RONC1360
Steering problem
1991 Toyota Camry 4 cyl Front Wheel Drive Automatic
Car steering is hard on extreme turns.
Power steering pump was replaced 2 years ago.
Fluid level is fine and circulating.
Tested with front wheels off the ground steering is fine both in park and drive.
Could the axle cv bearings cause this problem.
Mar 1, 2010 at 12:57 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Would you explain hard turning? Does steering wheel return to center after turn?
Mar 1, 2010 at 4:27 AM
RONC1360
Wheels return to center after turn.
Wheel becomes hard to turn on about the last 50% of the range For example when making making a 90 degree turn from a stop sign or making a u turn.
First part of turn seems to be OK.
Mar 1, 2010 at 4:37 AM
DOCFIXIT
  • 18,828 POSTS
Tires OEM size? Recent wheel alingment? Struts ever been replaced? Any steering pump whine or moaning?
Mar 1, 2010 at 5:17 AM
RONC1360
I hav OEM size tires.
Alignment a couple of months ago.
No opump whining or moaning.
Is it possibly a bad CV bearing?
Mar 1, 2010 at 5:28 AM
DOCFIXIT
  • 18,828 POSTS
Can't see Cv having a connection. Did this ocure sudenly?
Mar 1, 2010 at 5:41 AM
RONC1360
Mar 1, 2010 at 5:50 AM
DOCFIXIT
  • 18,828 POSTS
Think strut tower bearings maybe worn and binding in tight turn. would not show up wheels off ground because no weight on bearings. also ball joints maybe the problem.
Mar 1, 2010 at 5:58 AM
