Engine Mechanical problem
1990 Toyota Camry 4 cyl Front Wheel Drive Automatic
I was replacing the distributor cap, and removed the mass airflow sensor and hoses so Icould get to the srews on the cap. Well, I broke some of the connectors coming from the cable that plugs into the mass airflow sensor, and inside the sensor. The engine turns over, but after a couple seconds just dies. Is there a way I can bypass the sensor to drive the vehicle to the shop, or should I just order the part and install itmyself?
May 24, 2008 at 5:32 AM
