1989 Toyota Camry Power Window / Door Lock Issue
1989 TOYOTA CAMRY
89TOYCAM
Electrical problem
1989 Toyota Camry 4 cyl Two Wheel Drive Automatic
This is the first time I have written a question on this forum so here goes. I have a 1989 toyota camry wagon that is a tank. I have driven that car everywhere and I love it. The only problem has to do with the power windows and door locks.
The master switch (on the drivers side) works with the exception of the front passenger window switch and the door lock. both of those don't work at all
The front passenger side switch doesn't roll the window down but will roll it up and the door lock switch works.
The drivers side back seat window switch works.
The passenger side back seat only rolls down the window.
As a side note, I went ahead and manually got the passenger side rolled down one day just to test out the switch on the passenger side and found that the window would roll back up but it would not roll back down.
Also, I tried a new installing new window regulators and that didn't work and I also tried installing new switches and that didn't seem to work, unless it was just a stroke of luck that both switches didn't work in the same fashion.
If anyone can help me, thank you!
Aug 27, 2008 at 1:28 PM
