1989 Toyota Camry 4 cyl Front Wheel Drive Automatic 141k miles
My recently purchasded 1989 Toyota 4cyl. Camry is vibrating badly while stopped in drive, when the brake pedal is depressed. No noticable vibration if I put the car in neutral or park. The vibration only occurs when I put the car in drive with the brake pedal depressed. Car runs smooth as silk otherwise. Car has 141,000 on the speedo.I took it to the brake shop and they said it might be the brake booster but could not confirm. They said it could be a number of things, possibly a vaccum leak. The car was sitting for a year and started immediatly after a battery charge
SPONSORED LINKS
Monday, December 22nd, 2008 AT 5:35 PM
