HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Cylinder Head
Valve Cover
Gasket
Replace/Remove
1986 Toyota Camry valve cover gasket
LEARNING1
MEMBER
1986 TOYOTA CAMRY
4 CYL
2WD
AUTOMATIC
110,000 MILES
I would like to change the valve cover gasket because it is leaking. Any advise on how to do it correctly.
Thanks
Friday, August 14th, 2009 AT 12:29 PM
F4I_GUY
MECHANIC
Make sure you don't over-torque the valve cover bolts because they do snap easily.
Clean the gasket surfaces off well and apply a bit of silicone to the gasket and corners.
SPONSORED LINKS
Friday, August 14th, 2009 AT 8:42 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Valve Cover Gasket Replace/Remove Content
1997 Toyota Camry Replace Valve Cover Gaskets?
Engine Cooling Problem 1997 Toyota Camry 6 Cyl 145000 Miles Mechanic Quoting Me $365 To Change Both Valve Cover Gaskets, Which Seems...
Asked by
rgbrewer
1997
TOYOTA CAMRY
1998 Toyota Camry Cost Of Replacing Valve Cover...
Quoted 116.00+tax To Replace Valve Cover Gasket. Is This Reasonable
Asked by
blueisone
1 ANSWER
1998
TOYOTA CAMRY
1994 Camry
This Is A Beater Commuter Car That Has 197,000 Miles On It. I Parked It For A Week To Give It A Full Tune Up And Replace Some Gaskets That...
Asked by
Brittonp83
1 IMAGE
1994
TOYOTA CAMRY
1998 Toyota Camry Timing Belt & Valve Cover...
At How Many Miles Should I Get My Timing Belt Replaced? What Would Be A Reasonable Cost? Also The Cost For A Valve Cover Gasket Repair Job...
Asked by
esp22
1998
TOYOTA CAMRY
2000 Toyota Camry Oil Usage
My Camry Is Now "using" 1.5 Qts Between Oil Changes, Which I Consider Excessive For A 4 Qt Capacity. I've Always Changed My Oil Every 3000...
Asked by
cantgrowup
2000
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Engine Oil Leak
Throttle Actuator Service
Engine Oil Change and Filter Chevrolet
Online car repair manuals
