My oil was low and accidently i inserted Helix Diesel oil. A few adys later i checked the oil level eith the dip stick and it showed the oil level just below the second dot. When i opened the cap to put in more oil i noticed the oil had hardened, which is when i relised that i did somthing wrong. Do I need to worry about this and if so what should i do? Is this urgent?
Many thanks for your help and advise.
Feb 11, 2010 at 5:59 AM
