electrical issues
2001 TOYOTA AVALON
96,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMESON1310
my avalon keeps having electrical problems. if i left my car sit for more then 48 hours it will be dead and not start unless i jump start it. and then it will be fine until i let it sit again. i thought it might have ben the battery so i bought a new on and the same thing still happens. i also tried unhooking the battery after i had it started to see maybe if it was the alternator but it kept running. i know that is a old fashion way of testing but. do you have any idea what could be causing this issue? the car is completely stock no after market radio or anything as is
Jan 16, 2008 at 3:26 AM
MASTERTECHTIM
  • 4,750 POSTS
the first thing i always check is the glove box light, trunk light and map lights. one might be on by accident. feedback greatly appreciated.
Jan 16, 2008 at 3:33 AM
DUANED2
I have the same problem. Battery near death after two days of non use. The only thing that appears to be on is the flashing theft deterent light on the dashboard. I was about to go out and buy a new battery. Hope someone else has found the solution. Help!!!!
Jan 17, 2008 at 2:12 AM
MASTERTECHTIM
  • 4,750 POSTS
duaned2 check your lights also. you would be surprised how many map lights i find left on causing this problem. the theft light can not cause your draw, they run on such little power, that light could stay on for a year without your battery dying
Jan 17, 2008 at 3:43 AM
HADFARM1234
DId anyone ever find a solution tot he battery draw down problem? I am conswidering buying a used 2001 Toyota but has same exact issues - my regular mechanic wondered if it was due to an after market car alarm, but it is not.
Feb 3, 2013 at 5:59 AM
PETEMUCCI
Amazing to hear someone had same symptom... hammered the Toyota folks and incredibly they found the issue ... there is a switch at the trunk latch mechanism that controls the Trunk light... the switch was worn and believe it or not that bloody light was the culprit in draining the battery... luckily can be replaced without getting the latch as well which would of cost $250+but the switch was only like $50 plus labor total $100
Feb 25, 2014 at 7:09 AM
