1995 Toyota 4Runner Threw a Rod
SANSME
My car is a '95 Toyota 4-Runner, 2-wheel drive with 160,000 miles. We bought the car a couple of months ago very cheap beause it needed major repairs. We took it to the local Toyota dealership and told them to fix everything. It ended up costing $4000 but they told it was the engine was like new. Yesterday it threw a rod, no warning at all. The dealership is now telling us that it will cost $5900 for a new engine with labor. Well, the car's not worth that, but I just wonder why a car that is supposed to be like new would throw a rod. Every single oil leak was fixed, not to metion valve cover gaskets and who knows what all. I have 4 pages of repairs. Is there any way at all that this could be their fault by either not fixing something they should have or by not telling us something they should have?
Jan 9, 2007 at 6:47 AM
BACKYARDMECHANIC
  • 337 POSTS
Any engine with 160,000 miles is not like new no matter how many new parts you install unless you did a total rebuild on the motor. This would include but not limited to at least new rods and rod bearings. You also mention that the car had several oil leaks when you got the car which leads me to believe the engine was operated either with little or no oil at one time or another. Running a car with little or no oil can cause bearing failure. I hope this helps.
Jan 9, 2007 at 10:53 AM
Suggested Repair
Treat the thrown rod as likely rod-bearing failure, not a missed gasket repair. A 160,000-mile engine is not like new unless it had a full rebuild including rods and rod bearings. Prior oil leaks suggest it may have been run low on oil, which can destroy bearings. A new engine may not be worth the quoted cost.
Conversation Summary
The owner of a 1995 Toyota 4Runner with 160,000 miles said the dealership performed extensive repairs, including oil-leak fixes, and described the engine as like new. It later threw a rod without warning, and the dealer quoted a costly engine replacement. The expert explained that high mileage alone means the engine is not like new without a full rebuild including rods and bearings, and that earlier oil leaks suggest possible low-oil operation that can cause bearing failure.
