There's 2-fans 1-for the engine and 1-for the AC which 1 is not coming On.
Also check your coolant temperature sensor. This one tells the computer to activate the relay and then to the fan motor. Also a temperature switch could also be involved here.
Good Luck!
SPONSORED LINKS
Thursday, August 2nd, 2007 AT 12:34 AM
