1998 Toyota 4Runner WHERE IS THE NOISE COMING FROM
1998 TOYOTA 4RUNNER
131,488 MILES • 4 CYL • 2WD • AUTOMATIC
CHICO23
  • 39 POSTS
OK I HAVE A 98 TOYOTA 4RUNNER SR5 L4 ENGINE, ONE OF MY FIRENDS TOLD ME THAT I HAVE TO CHANGE THE WATER PUMP CAUSE THERE WAS A NOISE COMING FROM THE ENGINE. HE SAID THAT HAPPEN TO HIM TOO. IM NOT SURE IF ITS TRUE DO I REALLY NEED TO CHANGE THE WATER PUMP, CUZ THERE IS A MOISE COMIN FROM THER. THANK YOU PLEASE HELP
Jun 6, 2009 at 1:01 PM
  • 31,937 POSTS
HI there,
If there is coolant leaking from the small drain hole at the bottom of the pump the seal is failing and the pump should be replaced, if in doubt have a mechanic look at this and they will be able to advise you on what they see and hear, its a bit hard with out actually seeing or hearing this problem first hand.
Mark (mhpautos)
Apr 29, 2020 at 3:34 AM
