1998 Toyota 4Runner vehicle stumbles and stalls
MATS17
  • 1998 TOYOTA 4RUNNER
  • 4 CYL
  • 150,000 MILES
When I accelerate at a high rate then it stumbles and backfires. It doesnt do this when accelerating at a slower rate. Now it is also stalling when I slow down to come to a stop.
Monday, January 4th, 2010 AT 6:03 PM
Check and test below could be one of the following:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Monday, January 4th, 2010 AT 6:15 PM
