1995 Toyota 4Runner will not idle right and blows black sm
1995 TOYOTA 4RUNNER
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
GENAM007
I was having problems with gas mileage so I changed the plugs and wires on my vehicle since I did this the idle on the vehicle is under 1 and wants to stall unless you have your foot on the gas it also has black smoke coming from the exhaust that smell like gas the vehicle did not act like this before I have checked the timing and it does not seem to be that. Could you give me some insight. I feel that it could be a vacume problem
Aug 15, 2009 at 6:44 AM
Check the idle air control valve and also the following for a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.e and also the following
Aug 15, 2009 at 7:42 AM
