1995 Toyota 4Runner Engine Knock
291,000 MILES • 6 CYL • 4WD • AUTOMATIC
GREENONTAN
Driving my 4runner at 60 kmph notice a loud rattling. Pulled over and saw the oil pressure was extreemly low so i put 3qt of oil in. Now the rattling has stopped but it is making a very very loud knocking when idling and started, and when accelerating the knocking quickens and becomes even louder. I pulled the spark plugs 1 by 1 and the noise seems to be comming from the piston/cylinder on the passengerside closest to the dash. Anyone know if it's even safe to drive to a shop or should it be towed? And what could the problem be? The noise is just a very loud knock as if something is hitting something else in the engine.
Jan 3, 2008 at 6:55 AM
MERLIN2021
  • 17,250 POSTS
Sounds like either the wrist pin or connecting rod bearing, lack of oil wipes out bearings FAST! Don't be surprised to find more damage! Cannot say if it will get you far...
Jan 3, 2008 at 7:00 AM
GREENONTAN
Do you think it would be safe to drive to a shop, or should it be towed? It runs fine aside from the loud knocking
Jan 3, 2008 at 7:08 AM
