1993 Toyota 4Runner
JAMIE R
  • 1993 TOYOTA 4RUNNER
1993 Toyota 4Runner
my toyota 4runner keeps over heating and its leaking some where.I know its not the radietor but where could it be leaking and what is causing it to over heat?
Friday, September 24th, 2010 AT 10:33 AM
WRENCHTECH
  • 20,761 POSTS
There are dozens of places for it to leak. What you need to do is pressure test the cooling system and follow the leak to it's source.
Friday, September 24th, 2010 AT 11:02 AM
TINKSTER
  • 7 POSTS
Oh jeez! That happened to me and it was my water pump! I realized that after I blew a hose and cracked one of my heads! If you don't get it fixed right away this might happen to you and it is NOT cheap! I have a 92 4 runner and everything you said was exactly what I went through. I had a leak, thought it was my radiator (which I had to replace that too) I just kept adding water making sure the temp needle stayed below the half mark. I thought as long as it didn't over heat I was good to go! Not true. If your engine stays even a lil bit on the hotter side, you take the risk of messing your heads up. O! And mine was leaking too, I could see the drip but did not know where it was coming from, it was coming from my water pump. So get it checked ASAP!
Friday, September 24th, 2010 AT 11:05 PM
JAMIE R
Thanks for the replys.I went and bought a water pump and soon will have it on.I hope this fixes my problem but I am confident it will cause all of my problems sound like your response. Thanks again!
Saturday, September 25th, 2010 AT 7:49 PM
WRENCHTECH
  • 20,761 POSTS
Why are you assuming it's a bad water pump?
There are a dozen different places for that to leak and until you pressure test it, your making wild guesses.
Saturday, September 25th, 2010 AT 7:51 PM
