1992 Toyota 4Runner No fire in ingnition / no fuel pressure
1992 TOYOTA 4RUNNER
276,000 MILES • 6 CYL • 2WD • AUTOMATIC
IKEY ROEBUCK
I work offshore: 14/14 days: came in from work, vehicle setting for 14 days, running perfect when left. Now, engine will spin over very fast but will not start. Checked ingnition, no fire to plugs, distributor does rotate when engine spins, also check to see if any fuel to injector, no fuel pressure. Check all fues and EFI relay. Appear to be okay, relay ohms out at proper factory specs. ECM and all other ingnition system replaced new by me last fall. Check ECM with the old one (not bad) no changes. As stated running perfectly on trip to work (400 miles). If distributor turns timing belt should be okay?
What other suggestions do you have for me?
Jun 26, 2008 at 12:36 PM
BLACKOP555
  • 10,386 POSTS
first i will say if the distributor rotor is turning then the timing belt is good!
secondly i will want you to check out the ignition switch.
if its not working properly the starter could turn but you coudl get no spark or fuel signal to the pump.
does pump prime when key is turned to on?
Jun 26, 2008 at 3:44 PM
