1987 Toyota 4Runner 4 cyl Four Wheel Drive Manual 0
its had a new engine put in. The guy I got it from was running it with a carb. I took it off and put it back fuel injected like it came from the factory. Now it dont want to start and when it does it runs like junk. It will not idle and the only way you can start it is to prop onpen the mass air flow so the fuel pump runs. When running it run rough and skips. I have replace almost everything on it electrical and check everything else to make sure it tested right. Really frustrated and almost ready to put the carb back on.
SPONSORED LINKS
Tuesday, September 23rd, 2008 AT 2:06 PM
