Does this car have an emergency release?
65,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
DIVIDES
  • 903 POSTS
I need to tow it, bought it with no key as a repo, and it is parked with its rear towards a wall. Trying to see if there is a way to put it in neutral.
May 2, 2022 at 1:42 AM
STEVE W.
  • 15,415 POSTS
You have no emergency release as you need to release the electronic parking brake and put it in neutral and both need power to operate, and the key has to be turned on. To move it without a key will likely require a dolly system to load it.
May 2, 2022 at 5:37 AM
DIVIDES
  • 903 POSTS
Yes, i figured. What a stupid system. I have to drag it to the dealer to get a fob made.
May 2, 2022 at 5:42 AM
STEVE W.
  • 15,415 POSTS
That's Mercedes for you. What's worse is how many others are going the same way and making the cars into rolling computers with no mechanical back-ups.
The absolute worst vehicles I've seen like this are fire equipment. A vehicle that, when needed, must work, and they install computer-controlled valving and pump controls. One local department bought a fancy new engine with all the electronic toys on it, they made it into a big working structure fire and the system malfunctioned and they had no way to fight the fire! Ended up calling in some of us old school folks to fight the fire. They ended up running it for 6 months and it failed two more times, then they shipped it back and had the electronics stripped out and manual controls put in.
May 2, 2022 at 6:06 AM
DIVIDES
  • 903 POSTS
Geeez that's insane.
May 2, 2022 at 6:25 AM
