I am unable to remove the TORX bolt that holds the seatbelt to the floor. All the bits I have tried either twist in half or the adapter to the pull bar breaks. I had to take a side grinder to the passenger side but now have matting glued down and the sparks from the grinder may cause a fire.
Where can I find the proper TORX bit (size) that has the strength to take this bolt out of the floor. I am using hand tools to remove this bolt and anything less than 1/2" drive won't work. What name brand do the mechanics use that doesn't twist off?
Feb 8, 2019 at 9:12 AM
