Tire pressure light is blinking off and on
132,987 MILES • V6 • 2WD • AUTOMATIC
T. JOHN
  • 25 POSTS
This pasted Friday I was on the road and about seventy or so miles from home. I noticed the tire icon blinking off and on. So I stopped my truck got out and checked all the tires. All were a little high for being on the road. Released some air and went on to where I was going.
When I arrived it was still blinking. After about three houres or so I checked the pressure in all and they were a little high. So I made sure all the tires had the right pressure in them. Checked them late last night. All losted some air and so I put some in.
Now fast forward to today 9-25-17. Check them this morning and made sure all had the correct pressure in them.
I hope I gave you enough information So you can figure out what is wrong.
Sep 25, 2017 at 7:45 AM
  • 31,937 POSTS
Did you check the spare as if it is a full size tire it will have a pressure monitor fitted as well.
Sep 25, 2017 at 5:37 PM
STEVE W.
  • 15,418 POSTS
Do you have a TPMS tool or a scan tool that can read TPMS sensor status? Flashing TPMS light is a sign of a bad sensor that the system can no longer read. Steady light means low pressure. If they are OEM sensors I would say they did real good for battery life. Five to seven years is the design norm for the batteries.
Sep 25, 2017 at 7:21 PM
T. JOHN
  • 25 POSTS
I do not have a TMPS/SCAN tool. Do you know if they are expensive? I have read and watched videos that could be say one problem. Also, it might be the batteries going bad. If you would not mind would you send me your feed back. Also and do you know about how much each one would be and installing one or more?
Thanks.
Sep 25, 2017 at 10:01 PM
T. JOHN
  • 25 POSTS
I just thought about this one question. Is it say unwise/harming my truck to wait until say toward this Friday. I work some crazy days/hours.
Thanks again.
Sep 25, 2017 at 10:22 PM
STEVE W.
  • 15,418 POSTS
As long as you know the tire pressures are good the light is fine to ignore. I know people who put tape over the lights and just ignore it until they replace the tires or decide to sell the car. It is not anything critical.
It was actually put in place in response to Ford/Firestone tire failures. Both parties blamed the other and the government decided that the public must be protected from themselves.
As for the tools, unless you have deep pockets and plan on doing tire work a lot. You can have all four sensors, and the tires replaced for less that the TPMS tool costs.
The one I have was almost $1,000.00, Its current replacement is $900.00.
Sep 26, 2017 at 12:26 AM
T. JOHN
  • 25 POSTS
Thanks for answering all my questions for me. Great help.
Sep 26, 2017 at 1:53 AM
  • 55,766 POSTS
Please use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Sep 27, 2017 at 6:08 AM
