Tire compatibility
BOB01
  • 2003 CHEVROLET TRAILBLAZER
  • 6 CYL
  • 150,000 MILES
Can I use an LT245 75R17 in place of a P245 65R17 tire on a 2003 Trailblazer?
Saturday, April 13th, 2019 AT 5:58 PM
SCGRANTURISMO
  • 4,897 POSTS
Yes. As a matter of fact I would recommend using the "Light Truck" tires as opposed to the "Passenger car" tires as the first letter(s) in the tire size state.
Thanks,
Alex
2CarPros
Saturday, April 13th, 2019 AT 6:30 PM
BOB01
Awesome! Thank you very much.
Saturday, April 13th, 2019 AT 6:32 PM
  • 110,068 POSTS
Welcome to 2CarPros.
Just wanted to jump in here. Make sure the LT tire will not rub under the fender. When you change from a 65 to a 75, the tire will be taller and narrower. As far as the LT, I agree with Alex. An LT has a heavier sidewall which is designed to carry more weight. It can be up to a 10 ply sidewall. On the other hand, a P rated tire (passenger tire) will have a 4 ply side wall. It isn't designed for as much weight. Also, the change in size may have an affect on how the vehicle handles.
Monday, April 15th, 2019 AT 8:16 PM
