Tinking Sound From Belt under the hood
141,000 MILES • 6 CYL • AUTOMATIC
BHINCKLE
I started the car up and immediately heard a tinking noise. Lifted up the hood and you can tell just by the npise its coming from belt. I don't know if something broke or if the belt needs to bbe replaced or just greased up . It looks fine n not thin but I'm also not good at cars Lol. If you can help it'd be greatly appreciated. Thank you
Jan 11, 2014 at 4:57 AM
CARADIODOC
  • 34,417 POSTS
Noises from serpentine belts can be caused by them being loose or having insufficient tension from spring-loaded tensioner pulleys, but most commonly it's due to a pulley being turned or tipped, usually from a bad bearing. The noise is caused by the belt sliding across a pulley as it goes around it.
Do not put any kind of belt dressing, or "grease" on a serpentine belt. Dirt will stick to it and cause a lot more noise. The only fix for that is to discard the belt, scrub all of the pulleys with soap and water or an engine degreaser, then install a new belt.
Jan 11, 2014 at 7:47 AM
