Timing alignment cam verses distributor
180,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TWTTHOMAS
Well number one on my distributor is where number four goes, but engine runs okay. I believe someone put a timing belt in this car and did not use the up mark on the cam shaft. Instead of tearing it down again and fixing their mistake they just flipped the distributor wiring by starting out at number four with number 1, 3, 4, 2. It works because that is how this Honda is. Yes number one is were number four should be and it runs.
Feb 18, 2017 at 1:17 PM
  • 55,770 POSTS
Yes, this happens does the engine run okay or is there some kind of problem?
Best, Ken
Feb 20, 2017 at 10:37 AM
TWTTHOMAS
Thanks Ken yes it runs sufficient, they were lucky on this model do to even distribution on the cap design being equal. Tim
Feb 20, 2017 at 4:25 PM
