Engine fires and shudders for a second or two then shuts off
TKELLY2
  • 2005 FORD F-150
  • 5.0L
  • V8
  • 4WD
  • 309,000 MILES
High mileage, started vehicle and backed up 75 feet. Engine shook and shuddered and shut off. Now engine turns over easily, sometimes it may fire and shudder for a second or two then shuts off. My question is, is this the timing chain, or could it be the camshaft angle sensor?
Tuesday, February 26th, 2019 AT 6:46 AM
  • 109,936 POSTS
When you say it turns over easily, do you mean it is cranking faster than usual? If it is, then I suspect the timing chain jumped. However, there are many other things that can cause this issue if the starter speed is the same as always.
First, take a look through this link. It focuses on a crank no start condition.
If nothing there helps, I need you to check two things, fuel pressure and ignition spark. Here is a link that shows in general how to test fuel pressure:
Next, here is a link that shows how to check ignition spark:
If you have spark and fuel, then I need you to check engine compression. This will show if the timing has jumped or even if the compression is too low for the engine to run.
Here are a few links you may find helpful. Also, the last link shows how in general compression is tested.
https://www.2carpros.com/articles/the-reasons-for-low-compression
https://www.2carpros.com/articles/symptoms-of-low-compression
Perform these tests and let me know the results. Also, the 5.0L wasn't offered this year. If it is a V8, it should either be a 4.6L or the 5.4L. So, let me know specifically what engine you have.
Let me know if I can help or if you have other questions.
Tuesday, February 26th, 2019 AT 5:32 PM
