Timing
1972 FORD LTD
140,000 MILES • 5.8L • V8 • RWD • AUTOMATIC
NIGHTSTYLE
  • 11 POSTS
I recently replaced my carburetor, and then proceeded to have the engine backfire during a test drive. Was unable to completely start the car until I realized the timing was completely off. When I put the car at what I believe was top dead center, and removed the distributor cap I saw the pointer was at opposite side of piston number one. I proceeded to adjust the distributor, and after that was able to get the car to start, and run. However, now once I put the car into gear it will promptly cut off. I am still thinking it might be a timing issue, and attempted to use a timing light to adjust the timing to the manufacture settings. The problem is the timing pointer on the engine block is missing, and I have no reference for the marks on the crankshaft marks. I guess my two main concerns are is the engine cutting off still related to an timing issue, and if so how can I properly adjust the timing without that timing pointer? I am not sure they make one for that car, and trying to find one at a junkyard is proving difficult. Thanks for the help in advance.
Mar 13, 2017 at 1:31 AM
KHLOW2008
  • 41,814 POSTS
I believe you replaced the distributor and not the carburetor. Without the timing indicator, you can do a static ignition timing adjustment Manually turn the engine to number one piston at TDC on firing stroke. Attach a spark plug to number one plug wire and ground it.Turn ignition switch on and turn the distributor to get the spark plug to fire. Once it fires, stop turning the distributor. You have the ignition timing at 0 degrees. Turn distributor slightly forward to get advance. Note distributor position and from here you can try advancing or retarding with engine running.
Mar 13, 2017 at 1:50 AM
